sanostol Posted July 24, 2012 Share Posted July 24, 2012 Hi, I'm trying to update some rbds positions and rotations with pytondop. it works but it is slow. I use code like this: objects = hou.pwd().objectsToProcess() ctrl = hou.node("/obj/box_object1/add1") simulation = hou.node("..").simulation() for item in objects: id = simulation.findData(item.name()+"/CopyInfo/").options().field("copynum") .... I'm not sure if I get this right, but I think for every processed object the loop is run, for 1000 objects that means a lot of double work. so my question is there a way to do this just for the current processed object Martin Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted July 24, 2012 Share Posted July 24, 2012 You could easily test if it is running the loop for each object by putting a print in there and just using 3 objects or something. If it prints it more than 3 times its running it for each object. I feel that if it is running for each object there should be some function in hou.DopNode to get current object but I can't see any. Quote Link to comment Share on other sites More sharing options...
