baruch Posted July 24, 2012 Share Posted July 24, 2012 (edited) Hello I'm new here , and new in Houdini. im trying to do a test with RBD and debris System and i can't make it work... Any idia why? Thanks. here is a scene example Debris_test.hipFetching info... Edited July 25, 2012 by baruch Quote Link to comment Share on other sites More sharing options...
sadhu Posted July 25, 2012 Share Posted July 25, 2012 (edited) I think its a bug. 1)First you should go to rigidbodysolver dop , rclick select allow editing of contents. 2)Go to /obj/AutoDopNetwork/rigidbodysolver1/voronoifracturesolver1/fracture_SOP_solver and turn on create output groups. 3)Go to /obj/debris1/popnet/source_from_curves /impulserate you will come across the following expression if(ch("/obj/debris1/birthrate") == 0, argc(pointlist("/obj/AutoDopNetwork:emptyobject1/SourceGeometry", "birthcount")) * ch("/obj/debris1/multiplier"), if(argc(pointlist("/obj/AutoDopNetwork:emptyobject1/SourceGeometry", "birthcount")) > 0, ch("/obj/debris1/constant") , 0))if(ch("/obj/debris1/rate") == 0, argc(pointlist("/obj/AutoDopNetwork:emptyobject1/SourceGeometry", "birthcount")) * ch("/obj/debris1/multiplier"), if(argc(pointlist("/obj/AutoDopNetwork:emptyobject1/SourceGeometry", "birthcount")) > 0, ch("/obj/debris1/constant") , 0)) Its a faulty expression. There is no parameter called birtrate(ch("/obj/debris1/birthrate")) on debris object but its only rate and there is nothing called constant - ch("/obj/debris1/constant") so impulse birth rate becomes zero therefore no debris. Easiest solution is to delete this expression and write some constant number in impulse birth rate and set some life to the particles. I could not make sprites work. It is giving me an error 'infinite recursion' Debris.hipncFetching info... Edited July 25, 2012 by sadhu Quote Link to comment Share on other sites More sharing options...
baruch Posted July 25, 2012 Author Share Posted July 25, 2012 Hi Thank you for your replay. but i can't see the turn on create output groups" at the -fracture_SOP_solver-( image attached) and at part 3 didn't understend where I'm putting the expression at "source_from_curves" Thank you. Quote Link to comment Share on other sites More sharing options...
sadhu Posted July 25, 2012 Share Posted July 25, 2012 (edited) Sorry,my mistake. The path is /obj/AutoDopNetwork/rigidbodysolver1/voronoifracturesolver1/fracture_SOP_solver/voronoifracture double click on fracture_SOP_solver to jump in then go to voronoifracture. and the expression in the impulse birth rate is if(ch("/obj/debris1/birthrate") == 0, argc(pointlist("/obj/AutoDopNetwork:emptyobject1/SourceGeometry", "birthcount")) * ch("/obj/debris1/multiplier"), if(argc(pointlist("/obj/AutoDopNetwork:emptyobject1/SourceGeometry", "birthcount")) > 0, ch("/obj/debris1/constant") , 0)) In the first post I pasted it twice. but the following parameters are causing the problem ch("/obj/debris1/birthrate") ch("/obj/debris1/constant") One more change I made in your file is go to /obj/debris1/debris_geometry_setup/object_merge__dop_geo and write the following expression in it. /obj/AutoDopNetwork:piece*/Geometry - to import the Geometry of all the pieces. Please refer the file attached to my first post in this topic. Edited July 25, 2012 by sadhu Quote Link to comment Share on other sites More sharing options...
baruch Posted July 25, 2012 Author Share Posted July 25, 2012 Thank You so much! Happy to see it working. B Quote Link to comment Share on other sites More sharing options...
