cloudfx Posted July 25, 2012 Share Posted July 25, 2012 Hi, with python or any commands in textport or whatwever, how would I select a group with selecting a point or prim in the group? 1 Quote Link to comment Share on other sites More sharing options...
thinkinmonkey Posted July 25, 2012 Share Posted July 25, 2012 Hi, for what I read you should cycle all groups and prim/points to find a match. Anyway, in past I had a similar problem and I used this tricky way, I don't know if that's what you need, but here you go: selectGroupsAccordingSelectedPoints.hipnc There's this fractured sphere with groups (piece1, piece2, piece3...). I use a DELETE sop to have some points, in this way there will be only those groups that contain those (visible) points. Finally I use a second DELETE sop to delete all the groups, but the ones present in the previous DELETE sop with the following formula: `primgroupmask("../previousDelete","piece*")` I hope the explanation is clear and I strongly hope that's what you need. Happy magic, Michael Quote Link to comment Share on other sites More sharing options...
