RBD activation
Tom
So I was checking this scene from sidefx forum
http://www.sidefx.com/index2.php?option=com_forum&Itemid=172&page=download&id=11638
but I cant make it work on my object. It seems there is some problem with activation, because also inactive peaces ar falling with gravity.
Also, my mesh isnt colliding with ground plane.
My scene file is attached. I cant see what I did wrong.
frc_24_building_smash.hipnc
Edited by Tom
you need to change operation for Active value Parameter to Set Always
EDIT: and your geometry has flipped normals so add Reverse SOP before fracturing to flip Primitive Normals
and since you have vertex attribute N present on geometry which is flipped as well, you can add Vertex SOP as well and set Normal to Add with values -$NX, -$NY, -$NZ to flip it or Attribute SOP and write N to Verted/Delete parameter to get rid of it
then your collision should work
Edited by anim
  • 1 month later...
Thanks Tomas! It's working.
Totally forgot that normals are flipped, when importing from maya.
couple of questions about this technique. I was playing around with the file, and instead of having the points expand
via the attribute transfer I was just animating the sphere moving across the plane, and it works of course but as soon
as the red points leave the fracture doesn't move. Is there a way to leave a trail of sorts, so the pieces will continue
to fall when the sphere passes through them?
Also, I was interested in this file because I'm trying to achieve a wall fracture, but I only wanted the gravity to affect
the pieces which have forward velocity or are impacted by the object going through the wall. So I thought the forEach sop would be the best way to achieve this. But not sure.
Thanks
