lzoper Posted August 6, 2012 Share Posted August 6, 2012 Why ? If you disable the geometry of which is broken. then the sphere touches the ground on the frame 8, and if you turn on the geometry of the 2 she already disperses BagCollisions.hip Quote Link to comment Share on other sites More sharing options...
woodenduck Posted August 6, 2012 Share Posted August 6, 2012 Reduced impact radius, increase density on sphere. See .hip BagCollisions_v2.hip 1 Quote Link to comment Share on other sites More sharing options...
anim Posted August 6, 2012 Share Posted August 6, 2012 early fracturing it is caused by your Fracture object colliding with the Lanscape object to prevent that put * ^Lanscape into fractureparms/Impact Group parameter then you can decrease Min Impact parameter so the sphere will actually break it without changing its mass Quote Link to comment Share on other sites More sharing options...
