Is it possible to set a parameter value when a certain menu item is ch
I am not sure if this is possible, but I want to set an integer parameter to a calculated value from the UI, when a certain menu item is picked.
So let's say the user picked "poly" from the Primitive Type menu, I want to set an integer field to ch("sx") for instance.
Is this doable?
sure you can use parameter callback script to set that directly
or usually if it's from your asset you can call some function from HDA Python module which will do something when that parameter is changed
Thanks anim, will check it out now. Basically I want to set a value of a numeric parameter, let's say when you select Primitive Type "poly", I want to set the height to 5. That sort of thing. But after that the user is free to adjust that parameter himself, so it's not locked but just set to an initial value for a particular option.
Thanks anim, very useful example. I never used callbacks before so this is very helpful.
EDIT: Although I tried to create it from scratch but getting this error:
    def __getattr__(*args): return _hou.HDAModule___getattr__(*args)
AttributeError: 'module' object has no attribute 'setHeight'
I am using setHeight like you both for the function name, and the callback function call in the parameter.
Edited by magneto
it tells you that setHeight() function does not exist
you need to define that function in your asset
setHeight() is function I created in Scripts tab of the Asset, by creating Python Module and filled it with definition
so you need to define your function there if you want to call it, or of course you can call any function declared anywhere else
Yeah I saw that in your hip file, and added a function, but that's how I got the error. Let me see if I can create a simple test case.
EDIT: I think I found the problem. It's because of namespaces. Does this change how the callback function should be used?
hou.phm().setHeight(kwargs)
Will be something else?
Edited by magneto
I found the problem, it was due to some error in the script, which Houdini showed an error message for not being able to find the function because it was failed to be defined. It might be because of maybe I sent the errors to the console and it only printed the last error or I missed it. But it works now.
Thanks anim :)
