zarti Posted August 13, 2012 Share Posted August 13, 2012 hi everyone ! what im trying to do( with python )actually is this : im trying to transfer baked animations from obj level to sop level onto a transform sop . as far as i could read from hou section of docs it looks like 'asCode' is the way to go . but my question is this other one ; if i can easily copy( and read )channelData from parameters , How can i , with the same ease , 'paste' those data to the other node ?? is it possible ? i presume , building a chop net with fetch chops for each parameter tuples is another solution , but in this case id prefer a clean and stright Paste-method .. thanks for any help ! Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted August 13, 2012 Share Posted August 13, 2012 what im trying to do( with python )actually is this : im trying to transfer baked animations from obj level to sop level onto a transform sop . Hi, Why are you using python for this instead of just chops? Is your baked animation already saved as channel data? You could just use a file CHOP and then in the transform SOP add an expression to your transform channels pointing to the file CHOP. Even better, if you drag the specific channel from a motion view pane onto a parameter (tx for instance) houdini opens a little dialog box allowing you to choose between referencing options. Cheers Quote Link to comment Share on other sites More sharing options...
zarti Posted August 13, 2012 Author Share Posted August 13, 2012 hi Rafael and thanks for your reply ! actually im importing a simple simulation ( done in another app ) in fbx format . since every piece comes as an object , im trying initially to 'transfer' baked keyframes into sop transform nodes . so , this is an en-mass procedure .. .. and thats why i find the parmTuple.asCode() somehow inapropriate for my case . also hou module lets me easily pass tuples into Clipboard but i cannot find a simple way ( so to speak ) to pass again those keyframes into transform sops . i can read the keyframes using clipboardContainer() , .. those are there . also data doesnt exist yet as channels ( if by that you mean having those available in chop context ) maybe i need to re-create those keyframes 'one-by-one' in python if such 'function' doesnt exist yet . -- note : this is a test im doing mostly for learning and exploring python capabilities in houdini . Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted August 13, 2012 Share Posted August 13, 2012 hi Rafael and thanks for your reply ! actually im importing a simple simulation ( done in another app ) in fbx format . since every piece comes as an object , im trying initially to 'transfer' baked keyframes into sop transform nodes . so , this is an en-mass procedure .. .. and thats why i find the parmTuple.asCode() somehow inapropriate for my case . also hou module lets me easily pass tuples into Clipboard but i cannot find a simple way ( so to speak ) to pass again those keyframes into transform sops . i can read the keyframes using clipboardContainer() , .. those are there . also data doesnt exist yet as channels ( if by that you mean having those available in chop context ) maybe i need to re-create those keyframes 'one-by-one' in python if such 'function' doesnt exist yet . -- note : this is a test im doing mostly for learning and exploring python capabilities in houdini . I see... you could import your fbx into houdini then use the geometry chop to turn the baked animation into channel data, have you tried that? I was looking into the HOM reference and there's this object that could have been suitable for parsing animation data in the FBX: http://www.sidefx.com/docs/houdini12.1/hom/hou/Track The issue is that it's read-only unless you extend it... Another more interesting possibility is this example in the cookbook: http://www.sidefx.com/docs/houdini12.1/hom/cookbook/xforms_from_disk/ Cheers Quote Link to comment Share on other sites More sharing options...
