droplets with metaballs, whats wrong here?
hi, im trying to make a bunch of droplets over a surface, im almost fine when droplets are over a grid surface, but when is over sphere or other, metaballs are complete mess....
i wanna know which other methods could be for creating realistic droplets.
here is the hip.
Hello Arturo,
I took a look at your file and slightly modified it. The changes are all highlighted in Green.
Alternatively to metaballs, you can use the 'Particle Fluid Mesher' sop. I set that up in your file as well, so you can compare the two. The mesher is pretty fast and stable.
Hope that helps,
~Ilan
IG_DROPLETS_MIAS.hipnc
Hello Arturo,
Hope that helps,
~Ilan
THANKS A LOT DUDE!
  • Downvote 1
