Follyx Posted August 29, 2012 Share Posted August 29, 2012 Hi together, if I use a forcer i.e. Gravity, I dont see the "Icon" in the viewport. Is there a possibility to toggle it on or off or dou you have an other idea? Thank you in advance Quote Link to comment Share on other sites More sharing options...
wick3dParticle Posted August 29, 2012 Share Posted August 29, 2012 Hi Olly, Houdini is a bit different than the other 3d packages that most people are familiar with. Your gravity is built in to one of the nodes in your network, and it can vary depending on which kind of simulation you are running. It would be helpful to walk you through it if you include your scene file here. ~Ilan Quote Link to comment Share on other sites More sharing options...
