Bullet Solver - Initial Impact Subdata
TAkin
Hi all,
I have a simple set up here where a RBD object receives an impulse from a static object at the first frame. I have played with the 'split impulse' and 'collision padding' settings with were suggested by other members of the forum that commented on a similar problem.
I am hoping someone can actually help me with a concrete solution to this issue as I do not want that impulse/impetus on the first frame. Somewhere in the help files, it says:
"The Bullet solver does not have the option to distinguish resting impact in impact data."
I was hoping there would be a work around for this problem.
I do not want to settle for the RBD solver as I want to take advantage of the bullet solver's speed because I would be simulating a lot of objects.
Every intuition offered would be appreciated :)
