Croping in CHOP
Greetings
I do simple animation and want to take part of it and stretch/shrink
I use stretch OP but it stretch/shrink whole animtion
I just want to shrink between frame 33 and 77,for example
Second,shrinking/stretching should(not) influence previous frames,
like option to pull frames before when shrinking,push forward when stretching or to stay in place.
Something as Time Warp in MB that I
I don't think you mean CHOPs? I think you means regular keyframe channels right? Just retime the keys you want using the dopesheet (of the channel editor).
I don't understand your last question. You want to break the slopes? In the graph mode of the channel editor, select both slopes that you want to break and then hit t. Now select only one of the slopes and adjust.
If you're animating in Houdini, it's very important that you thoroughly learn how to use the channel editor. Read the whole chapter on the channel editor under Help > Interface > Channel Editor.
Hi there,
This is possible in CHOPs, but I really thinking you are wanting to do this in the Channel Editor either in the Graph mode or the Dopesheet mode. It's easy to select regions and then move/squash/stretch the keyframes.
