Shader LUT
Macha
Has anybody worked on shaders parts that 'undo' LUTs?
I have a rather tricky volume shader that maps density to color and it's very finicky in the way it maps accumulated voxel density to pixel density. So, once I worked out a good color palette and apply a LUT it goes all wonky again.
There should be a way to apply an inverse of a LUT, since it is just a function mapping from one R3 space to another, and an inverse exists.
Has anybody tried that before?
Edited by Macha
Thanks Edward. I assumed -hoped- LUTs were 1-1 maps. Maybe they are clamped at the top and bottom values.
Do you think we could plot the effect of LUTs on RGB values in COPs? If at least I have some idea of how they behave I could build an approximate inverse function for it.
Is there any good online explanation of how LUTs are represented? Is there a standard of sorts?
There's generally 2 main types of LUTs - curve based LUTs, and 3D LUTs. Curve-based LUTs are fairly easy to invert as long as they're continually increasing in value. If they double back on themselves (like a U) then they cannot be inverted.
3D LUTs are best visualized as a giant color cube. They can be inverted by creating a point cloud out of the the output values in 3D LUT space (position = output value, Cd value = input value) then sampling the nearby points for Cd, for all entries in the inverse LUT. However, you can run into the same issues as curve-based LUTs if more than one 3D LUT entry maps to the same output value.
Our LUTs are described in detail here: http://www.sidefx.co...hdk_io_lut.html
