woodenduck Posted October 5, 2012 Share Posted October 5, 2012 Hi guys, I'm having a bit of trouble here. I've got my HOT ocean nicely deforming and now I'm working on the shader. I'm using the HOT_Ocean_Eval vop and it's causing an error. It's giving me "Call to undefined function ocean_eval()" Has anybody got any ideas why this might be? Like I said, the ocean sop is working fine, it's just the vops that are causing me trouble. Maybe I didn't install it ptoperly??? Any thoughts, Thanks, WD Quote Link to comment Share on other sites More sharing options...
eloop Posted October 18, 2012 Share Posted October 18, 2012 Make sure you have the VEXdso file installed properly. Quote Link to comment Share on other sites More sharing options...
woodenduck Posted October 19, 2012 Author Share Posted October 19, 2012 I've certainly tried that, I must be doing something wrong. Do you know what the correct procedure should be? Thanks for your help, WD Quote Link to comment Share on other sites More sharing options...
magicrystal Posted January 3, 2013 Share Posted January 3, 2013 You need to define VEX plug-in functions in \Houdini xx.x.xxx\houdini\vex\VEXdso file. just add a new line: VEX_Ocean.dll Quote Link to comment Share on other sites More sharing options...
