cloudfx Posted October 7, 2012 Share Posted October 7, 2012 I understand "coef_1 * val_1 OP coef_2 * val_2 OP coef_3 * val_3 OP constant" but for coefficient (for example coef_1 ..2 and so on) There are drop down menus for Timestep , e^Timestep. I see "set always" down there which will evaluate every frame with current value but what about the Timestep and e^Timestep? what does that do exactly? Quote Link to comment Share on other sites More sharing options...
Macha Posted October 7, 2012 Share Posted October 7, 2012 (edited) I'm interested in that too. I have no idea but propose a guess: When you run through numerical methods you need to decide the size of your time steps. Larger is faster but less accurate. (I think in the methods here are stable, even very large steps will result in bounded values and not blow up your sim). An exponential time stepping would make bigger and bigger time steps to get changing accuracy where it matters (the first few steps). I never use those timesteps and would be happy to see how they are used properly. Edited October 7, 2012 by Macha Quote Link to comment Share on other sites More sharing options...
cloudfx Posted October 7, 2012 Author Share Posted October 7, 2012 I'm interested in that too. I have no idea but propose a guess: When you run through numerical methods you need to decide the size of your time steps. Larger is faster but less accurate. (I think in the methods here are stable, even very large steps will result in bounded values and not blow up your sim). An exponential time stepping would make bigger and bigger time steps to get changing accuracy where it matters (the first few steps). I never use those timesteps and would be happy to see how they are used properly. Hi Macha, I just made to see the difference between "none" , "timestep" , "1/timestep" and "e^timestep" It seems, none is just 1+1 , timestep is 1+1/24 , 1/timestep is 1+24/1 , e^timestep is 1+(*exponential curve) but I am not sure, take a look at the hip file if you get a chance. Thank you, gas_linear_example.hip Quote Link to comment Share on other sites More sharing options...
