trisen Posted November 10, 2012 Share Posted November 10, 2012 We have two sequences. Goal - make some sort of morph between the Vase and the Jar. I have decided to make it via particles and some Vop Pop. Here is the current previz: 1 Quote Link to comment Share on other sites More sharing options...
gui Posted November 10, 2012 Share Posted November 10, 2012 Cool, are they images or 3d models? Quote Link to comment Share on other sites More sharing options...
trisen Posted November 10, 2012 Author Share Posted November 10, 2012 (edited) Cool, are they images or 3d models? Two 3d models with camera projected textures Edited November 10, 2012 by trisen Quote Link to comment Share on other sites More sharing options...
JuriBryan Posted November 11, 2012 Share Posted November 11, 2012 hey, I have created a tool for exactly those kinda things. If you would like to take a look at it: http://juribryanfx.com/houdini-tools/ Cheers, Juri Quote Link to comment Share on other sites More sharing options...
trisen Posted November 14, 2012 Author Share Posted November 14, 2012 I have a question. As 3d models is not ideal I need to make point alpha based on the alpha channel of the image (from which a tool color of the particles via camera projection ) And there is no any alpha output in vop pop. Also I mix particle color from one image to another by particle life, also need to mix and alpha. Any solution? thanks Quote Link to comment Share on other sites More sharing options...
JuriBryan Posted November 14, 2012 Share Posted November 14, 2012 why do you want to do it in PoPs? you can do it with a simple VoP Sop that gives you a lot of control and makes it easier to work with the colours and alphas. Just add a parameter name it Alpha and there you go. Now you can do with it what ever you want. If you want to do it in PoPs one way would be to use point cloud open and point cloud filter to get the data off the two geo pieces by projecting the images on points that you scattered on the geo, then simply call those points in PoPs and you should get the with the point cloud filter what ever data you have on the points you call. Now you can use alpha and colours from objects that are not in you pop chain in you VoP Pops. I hope that helps, you could post the hip file, then I could try and implement a basic set up to show you what I mean. cheers, Juri Quote Link to comment Share on other sites More sharing options...
kstrod20 Posted May 12, 2014 Share Posted May 12, 2014 How did you camera project onto particles without the texture swimming? Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted May 12, 2014 Share Posted May 12, 2014 You can create rest or uv attribute on first frame or when particles are born. Quote Link to comment Share on other sites More sharing options...
