Exporting velocity visualisation maps
dynamoanders
Well... If I understand...
You want to render the streamers, they are the standard velocity visualization.
First of all, you need to bring the streamers to SOP level. So turn the velocity visualization ON, inside the AutoDopNetwork network. Then go to import_pyro_build, put the render flag to import_pyro_visualization and type in the Geometry Data Path vel/Visualization.
Is that it?
