spring network constraint for rbd
qbick
there is node called gluenetworkconstraint and its working fine.
my question is - is there any way to create the exact network constraint but with spring constraints instead of glue one.
there is springnetworkconstraint node, but it is for SBD only.
ive attached scenefile with gluenetworkconstraint, if someone will be able to modify it - it would be much appreciated.
thanks
https://www.dropbox.com/s/6dceptymme2cvjz/test.hipnc
Edited by qbick
