compile houdini 12 hdk
fayal
Windows, Linux, OSX? My advice is don't attempt to setup IDE now, start with command line compilation, inspect compilation flags, make some coding. You won't need "IDE experience" for a while, if you've just stared. After some time you will know more about HDK and it will be easier to advance. The tutorial in HDK explains every step in command compilation.
If you insist using IDE now, read Makefile for your platform (it's there in $HT/makefiles) and dress your compiler and linker with those flags.
