How render faster with area lights (soft shadows with less noise?)
Keep the render samples and pixel samples on the Mantra node as low as you can and then increase the samples on the light object to improve the shadow quality. There's no silver bullet because it will simple take a lot of samples but that should help some depending on how you're doing things now.
Thank you
It helped.
I'm messing with the lit fog too.
any suggestions.
