vtwinracersp2 Posted November 27, 2012 Share Posted November 27, 2012 anyone have an example hip scene that uses the hdk example sim_solverhair.c? there is a note in the header file, but i don't think i'm setting this up right. Would EmptyObject be pointing to some wire object? /* * The simplest network to see something working with this... * * RBD Object EmptyObject * \ | * \ HairSolver * \ | * \__ Gravity * \ / * Merge * * The gravity node should be set to have a non-zero X velocity. * The HairSolver node should have the name of the rbd object * (default rbdobject1) as its Source Object. */ Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted August 26, 2014 Share Posted August 26, 2014 I t would be great if someone could share a simple hip file for this hdk sample. I can't make this to work. Quote Link to comment Share on other sites More sharing options...
iamyoukou Posted December 30, 2016 Share Posted December 30, 2016 On 8/26/2014 at 8:25 AM, Stalkerx777 said: I t would be great if someone could share a simple hip file for this hdk sample. I can't make this to work. Expand Me, too. I also can't get SNOW_Solver.dylib to work X_X Quote Link to comment Share on other sites More sharing options...
