need help with spotlight and obj import
I'm new to houdini and have questions if someone can help out I'll be very happy
Whenever I put a light in my scene and Enable Spot Light my objects dissapear, when I uncheck "enable spot light" and check again houdini crashes, my video card is gtx 580 3GB with latest drivers and I'm using high quality lighting.
My second question is when I try to put an object into File it doesn't appear in my viewport and I get an error "Geometry not cooked"
can someone help me to solve this issues please?
This issue was fixed in 12.1.138.
What file format are you trying to load? Also, make sure you are not in "Manual" update mode (lower-right corner).
It's hard to help you without providing any details/hip file.
Common problem with importing geometry (specially with '+' key) is a trailing digit in a file name, which will be (erroneously*) collapsed into $F, so the path is expanded to file[whatever_frame_on_timebar].obj instead of mybox1.obj. You can fix it by manually removing $F from a path name. Other than that, obj should import nicely :)
good luck!
skk.
* this, along with a collapse all digits sequence in a file name, instead of only last one (before dot followed by extension), is a long standing issue in Houdini.
