acey195 Posted December 6, 2012 Share Posted December 6, 2012 Hello, been lurking a bit, but time for a first post, Yeah Ok, I have a small object (bounding box is 1 unit in each direction) with a high density of polygons. When I use Polyreduce on this, it reduces nothing at all, however when I simply scale the object up, do a poly reduce and scale it back down, it works. Does anyone know why this happens? And if so, are the more nodes that are scale dependent? (attrib transfer, maybe?) Acey Quote Link to comment Share on other sites More sharing options...
freaq Posted December 6, 2012 Share Posted December 6, 2012 the polyreduce is indeed scale dependent for some reason, scaling up models can help with very aggressive polyreduction. as far as the attribute transfer goes it is dependant on scale but not in the same way, it won;t help the performance of the node but if things are built very small it can be hard to dial in the values. but very few nodes will bug out like the polyreduce with very small scales. (at sop level, atm I can;t think of any) Quote Link to comment Share on other sites More sharing options...
acey195 Posted December 6, 2012 Author Share Posted December 6, 2012 Thanks Freek Quote Link to comment Share on other sites More sharing options...
michael Posted December 6, 2012 Share Posted December 6, 2012 I'd say any node that relies on a radius will be affected by scale. Quote Link to comment Share on other sites More sharing options...
acey195 Posted December 6, 2012 Author Share Posted December 6, 2012 Of course, but polyreduce has no setting for said radius. Or at least I cannot find one. It seems that it does not work altogether, above a certain polygon density, or below a certain polygon size. My personal guess is that its accuracy has been "hardcoded" Possibly to make values fit within float values, rather than needing to resort to doubles. Quote Link to comment Share on other sites More sharing options...
