little Posted December 6, 2012 Share Posted December 6, 2012 I am trying to write some data to the viewport using 'GL_ViewportFont' class. I declared its object and RE_Render object: GR_ViewportFont *data = new GR_ViewportFont; RE_Render *ren = new RE_Render(0,"viewport"); I am calling data->int label (RE_Render *r, const UT_String &str, const UT_Vector3F &pos, const UT_Vector3F &col, fpreal32 *&dst_points, fpreal32 *&dst_texcoord, fpreal32 *&dst_colors, XPosition xpos, YPosition ypos, fpreal &x_offset) const by passing some constants to this function. As soon as I run Houdini it crashes on this function call. I am creating a SOP node and calling this function from within the cookMySop method. 1. Should I be calling this from cookMy Sop? 2. Am I defining RE_Render incorrectly? Since Houdini does not print out any error on crashing I have no idea where I am going wrong. Does anyone know about this or any other alternate solution ? Thanks!!! Quote Link to comment Share on other sites More sharing options...
