fluid regarding activation and deactivation
Hello world
Hi I want to emit fluids from a certain and also to appear the fluid to stop its activation.the other thing is that the geometry appears on say frame 1 5 10 15.so I want to have the same activaation and velocity controls to all the four sources where it will emit the flip.how can i achieve this?
I have also attached the file in case my question is not clear
PS the foreach is obsolete.I thought of creating a dop net inside it.
odforce dop question.hip
Edited by Hello world
just animate your source geometry parts so that they appear and disappear on frames you want your activation/deactivation (expressions, CHOPs, keyframes)
the fluid emission will behave accordingly
and never use any simulation environment inside of the foreach SOP, it will not work
