Vop-Network inaccessible
FromHell
hey thanks for your reply! "i" and "enter" doesn't work either...
may be I'm doing something wrong? I first pressed the "tab" key then from the menu>surface>"Shadow matte" and now , after it is created i should be able to open up this VOP - node, shouldn't I?
By the way, I just found your network, I don't know what you are trying to do, but in shadowMatte you cannot enter: some nodes are created by programming or have scripts.
Press right mouse button on shadowMatte node and select TYPE PROPERTIES.
Then go to CODE tab and see the code: the node has no internal network, it's execute code associated with it.
