How to control the point mapping of Skin SOP?
magneto
yes, it's by vertex order
connect Primitive SOP to one of your polygons and in Face/Hull tab under Vertex parameter you have options to shift or reverse the vertex order which will affect the Skin SOP
if you want to make completely arbitrary pairs though one way to do it may be connecting the points with Add SOP then skin those lines
