kleer001 Posted January 7, 2013 Share Posted January 7, 2013 Anyone try their hand in Houdini at simulating oobleck (a fun mix of corn starch and water)? Here's some guys drooling over the science: Here's some fun with it: It seems like altering viscosity based on velocity in a SOP solver should be easy enough. I'll give it a try and report back... some day. Quote Link to comment Share on other sites More sharing options...
Solitude Posted January 8, 2013 Share Posted January 8, 2013 (edited) I've done it like you said but instead of velocity I used vorticity. Velocity should work well too. I was able to get the fluid to stiffen up as a sphere collided with it, then go back to low viscosity after it calmed down, but if the mapping of ranges wasn't correct, it could easily freak out. Edit: Uploaded a file. Not perfect, but it certainly is a start. Also, I used the same technique to create effervescence by modifying density based on vorticity, so the areas with a lot of motion would then rise up in the fluid. --Ian h12_Vorticity_oobleck.hip Edited January 8, 2013 by Solitude Quote Link to comment Share on other sites More sharing options...
