file object - tree
xs2222
Hi Folks,
I have a tree obj and need to sepearate its leaves from the branches to make it dynamic, any ideas !
so that the leaves and brances have separate control , or any other way of adding control to the file obj
thanks,
xs
you could try using the connectivity SOP -> partition SOP to get the separation of the leaves and branches, it will output a whole bunch of groups for you to play around with.
For the dynamics part you could use wire solvers for the branches and cloth solvers for the leaves
Cheers,
- Joel
