Crumbling Piller
ntkirby
ok so update on this
I fixed the issue where it wasn't taking into acct the tolerance, so the tolerance setting for each level is now a default of .001 and you can still adjust it
also I figured out that this has an easier time cutting up simple shapes no matter how many of them there are
EDIT: I uploaded the wrong asset file, the correct one is uploaded
ntk_k_fracture.otlFetching info...
Edited by frescalus
  • 2 weeks later...
Alright! I think I got it now..
This is nearly a fully developed recursive fracturing tool.
I have also provided a sample scene so you can see what I have done.
After doing some research, looking around some forums at other scenes and such, this is what I came up with.
If you have any suggestions or feedback to improve this please let me know.
And here is the video in which I have taken those pieces and turned them into rbd pieces
https://vimeo.com/59702611
recursive_fracture.hipncFetching info...
Edited by frescalus
I'm actually using a voronoi fracture over and over again, the thing that I'm doing though with this is that I'm getting the area of the object and that's how I determine whether it gets fractured or not.
Its nothing special, I just wanted people to see how I did this is all and offer up any suggestions
