how to make variable evaluate in real time?
panupat
Hi. A total new Houdini user here :) I'm following some tutorial on Youtube and it's showing how to use $F in channel box. In the video, the value got updated in real time as the user scroll the time line (or click play button). However in my Houdini the value only updates when I release my mouse to after I click the stop button. How can I make it update in real time?
Edited by panupat
Thanks Graham!
I have another question. When I copy parameter and do a Paste Copied Reference, is there a way to paste without replacing what's already there?
For example I have
ch("/obj/stair/copy1/ncy")
And I want to add ty
ch("/obj/stair/copy1/ncy") * ch("/obj/stair/copy1/ty")
But when I paste ty, it replaces the whole thing.
It's been a long-time requested feature and nope, it's not possible yet... :(
What most people do is paste copied reference to another parameter and then cut-and-paste in the desired parameter.
Cheers
Ah that's quite a surprised :blink:
@Graham - sounds a bit advance... I'm sure I'll be able to do that someday!
Thanks guys.
Edited by panupat
It is quite possible to actually write something like this yourself by using the information returned by hou.parmClipboardContents() and custom PARMmenu.xml entries.
Awesome! I'm reading about it now...
Now if it's so easy why is it not a default behavior?! :S
Indeed, I just managed to write one and it works quite nicely, except that I can't disable the commands when the hou.parmClipboardContents is empty.
Thanks for the tip, Graham!
Cheers
Cheers
hi Rafael ,
rambling in vain through houdini py and xml files didnt helped me to understand or ' connect things ' .
since my interest in changing the RightClickMenu-s is , actually , greater than my shame about asking " how can i ? " so
, here it comes my brave question :
=) how could you make it ??
can you describe in short what you modified ?
.cheers
Hey Zarti, I generally post files, but in this case, since I was figuring this out at work and later shared with the team, I was a bit concerned that it would be looked upon badly... :ph34r:
Nevertheless, here goes a quickie. I mainly looked at this page of the documentation:
http://www.sidefx.com/docs/houdini12.1/basics/config_menus
From there I learned about creating the PARMmenu.xml inside my $HOME/houdinixx.x/
The contents of my XML are:
<?xml version="1.0" encoding="UTF-8"?>
<menuDocument>
<menu>
<addScriptItem id="append_ref">
<parent>root_menu</parent>
<label>Append Copied References</label>
<scriptPath>append_reference.py</scriptPath>
<insertBefore>del_channels</insertBefore>
<scriptArgs>-abs</scriptArgs>
</addScriptItem>
</menu>
<menu>
<addScriptItem id="append_rel_ref">
<label>Append Copied Relative References</label>
<scriptArgs>-rel</scriptArgs>
</addScriptItem>
</menu>
</menuDocument>
[/CODE]
You'll have to modify the scriptpath tag with the path to your script in your machine
My python script is this:
[CODE]
# imports the hou module so we can start accessing houdini's commands
import hou
from sys import argv
def append_ref(mykwargs, mode='-abs'):
# check for contents of parm clipboard
myParmClip = hou.parmClipboardContents()
if myParmClip != ():
relPathPrefix = mykwargs['parms'][0].node().relativePathTo(hou.parm(myParmClip[0]['path']).node())
for i in range(min(len(myParmClip), len(mykwargs['parms']))):
parmFrom = {'path':myParmClip[i]['path'], 'language':myParmClip[i]['expressionLanguage'], 'name':hou.parm(myParmClip[i]['path']).name()}
parmTo = mykwargs['parms'][i]
# test if parm already has an expression assigned
try:
parmToExp = {'expression':parmTo.expression(), 'language':parmTo.expressionLanguage()}
except:
parmToExp = {'expression':"", 'language':hou.exprLanguage.Hscript}
# sets the expressions
if argv[1] == '-abs':
parmTo.setExpression(expression=parmToExp['expression'] + "ch(\"" + parmFrom['path'] + "\")", language=parmToExp['language'])
elif argv[1] == '-rel':
parmTo.setExpression(expression=parmToExp['expression'] + "ch(\"" + relPathPrefix + "/" + parmFrom['name'] + "\")", language=parmToExp['language'])
# return success
return 0
else:
# return failure
return -1
append_ref(kwargs, argv[1])
[/CODE]
Now, while it does work fine here, I'm not proud of the code nor do I guarantee anything! :D
Cheers
http://www.sidefx.co...cs/config_menus
Cheers
oho ! it works and you should be proud even if it was only just for the link to onlineDocs .. =)
searching with 'menu' keyword on helpSytem brought many other thing , but ..
anyway , thanks Rafael . appreciate your reply .
.cheers
