panupat Posted January 27, 2013 Share Posted January 27, 2013 (edited) Hi. A total new Houdini user here I'm following some tutorial on Youtube and it's showing how to use $F in channel box. In the video, the value got updated in real time as the user scroll the time line (or click play button). However in my Houdini the value only updates when I release my mouse to after I click the stop button. How can I make it update in real time? Edited January 27, 2013 by panupat Quote Link to comment Share on other sites More sharing options...
graham Posted January 27, 2013 Share Posted January 27, 2013 You need to enable Continuous Parameter Updates: http://www.sidefx.com/docs/houdini12.1/basics/cooking 1 Quote Link to comment Share on other sites More sharing options...
panupat Posted January 29, 2013 Author Share Posted January 29, 2013 Thanks Graham! I have another question. When I copy parameter and do a Paste Copied Reference, is there a way to paste without replacing what's already there? For example I have ch("/obj/stair/copy1/ncy") And I want to add ty ch("/obj/stair/copy1/ncy") * ch("/obj/stair/copy1/ty") But when I paste ty, it replaces the whole thing. Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted January 29, 2013 Share Posted January 29, 2013 On 1/29/2013 at 2:29 PM, panupat said: I have another question. When I copy parameter and do a Paste Copied Reference, is there a way to paste without replacing what's already there? It's been a long-time requested feature and nope, it's not possible yet... What most people do is paste copied reference to another parameter and then cut-and-paste in the desired parameter. Cheers 1 Quote Link to comment Share on other sites More sharing options...
graham Posted January 29, 2013 Share Posted January 29, 2013 It is quite possible to actually write something like this yourself by using the information returned by hou.parmClipboardContents() and custom PARMmenu.xml entries. 2 Quote Link to comment Share on other sites More sharing options...
panupat Posted January 29, 2013 Author Share Posted January 29, 2013 (edited) On 1/29/2013 at 2:33 PM, rafaelfs said: It's been a long-time requested feature and nope, it's not possible yet... Ah that's quite a surprised @Graham - sounds a bit advance... I'm sure I'll be able to do that someday! Thanks guys. Edited January 29, 2013 by panupat Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted January 29, 2013 Share Posted January 29, 2013 On 1/29/2013 at 3:29 PM, graham said: It is quite possible to actually write something like this yourself by using the information returned by hou.parmClipboardContents() and custom PARMmenu.xml entries. Awesome! I'm reading about it now... Now if it's so easy why is it not a default behavior?! :S Quote Link to comment Share on other sites More sharing options...
Netvudu Posted January 29, 2013 Share Posted January 29, 2013 It would be nice to have it there. It happens quite a lot, and it´s indeed, boring... ...though I chuckle at the idea that we have 5 paste styles already and we still need more Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted January 29, 2013 Share Posted January 29, 2013 On 1/29/2013 at 3:29 PM, graham said: It is quite possible to actually write something like this yourself by using the information returned by hou.parmClipboardContents() and custom PARMmenu.xml entries. Indeed, I just managed to write one and it works quite nicely, except that I can't disable the commands when the hou.parmClipboardContents is empty. Thanks for the tip, Graham! Cheers Quote Link to comment Share on other sites More sharing options...
panupat Posted January 30, 2013 Author Share Posted January 30, 2013 How do I adjust the range of sliders? For example the copy amount which defaults to 0-20. If I want the slider to go all the way to 100, can I do that? Quote Link to comment Share on other sites More sharing options...
zarti Posted January 30, 2013 Share Posted January 30, 2013 On 1/29/2013 at 11:17 PM, rafaelfs said: Indeed, I just managed to write one and it works quite nicely, except that I can't disable the commands when the hou.parmClipboardContents is empty. Thanks for the tip, Graham! Cheers hi Rafael , rambling in vain through houdini py and xml files didnt helped me to understand or ' connect things ' . since my interest in changing the RightClickMenu-s is , actually , greater than my shame about asking " how can i ? " so , here it comes my brave question : =) how could you make it ?? can you describe in short what you modified ? .cheers Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted January 31, 2013 Share Posted January 31, 2013 On 1/30/2013 at 11:21 PM, zarti said: can you describe in short what you modified ? Hey Zarti, I generally post files, but in this case, since I was figuring this out at work and later shared with the team, I was a bit concerned that it would be looked upon badly... Nevertheless, here goes a quickie. I mainly looked at this page of the documentation: http://www.sidefx.com/docs/houdini12.1/basics/config_menus From there I learned about creating the PARMmenu.xml inside my $HOME/houdinixx.x/ The contents of my XML are: <?xml version="1.0" encoding="UTF-8"?><menuDocument><menu> <addScriptItem id="append_ref"> <parent>root_menu</parent> <label>Append Copied References</label> <scriptPath>append_reference.py</scriptPath> <insertBefore>del_channels</insertBefore> <scriptArgs>-abs</scriptArgs> </addScriptItem></menu><menu> <addScriptItem id="append_rel_ref"> <parent>root_menu</parent> <label>Append Copied Relative References</label> <scriptPath>append_reference.py</scriptPath> <insertBefore>del_channels</insertBefore> <scriptArgs>-rel</scriptArgs> </addScriptItem></menu></menuDocument>[/CODE]You'll have to modify the scriptpath tag with the path to your script in your machineMy python script is this:[CODE]# imports the hou module so we can start accessing houdini's commandsimport houfrom sys import argvdef append_ref(mykwargs, mode='-abs'): # check for contents of parm clipboard myParmClip = hou.parmClipboardContents() if myParmClip != (): relPathPrefix = mykwargs['parms'][0].node().relativePathTo(hou.parm(myParmClip[0]['path']).node()) for i in range(min(len(myParmClip), len(mykwargs['parms']))): parmFrom = {'path':myParmClip[i]['path'], 'language':myParmClip[i]['expressionLanguage'], 'name':hou.parm(myParmClip[i]['path']).name()} parmTo = mykwargs['parms'][i] # test if parm already has an expression assigned try: parmToExp = {'expression':parmTo.expression(), 'language':parmTo.expressionLanguage()} except: parmToExp = {'expression':"", 'language':hou.exprLanguage.Hscript} # sets the expressions if argv[1] == '-abs': parmTo.setExpression(expression=parmToExp['expression'] + "ch(\"" + parmFrom['path'] + "\")", language=parmToExp['language']) elif argv[1] == '-rel': parmTo.setExpression(expression=parmToExp['expression'] + "ch(\"" + relPathPrefix + "/" + parmFrom['name'] + "\")", language=parmToExp['language']) # return success return 0 else: # return failure return -1append_ref(kwargs, argv[1])[/CODE]Now, while it does work fine here, I'm not proud of the code nor do I guarantee anything! Cheers 1 Quote Link to comment Share on other sites More sharing options...
zarti Posted January 31, 2013 Share Posted January 31, 2013 On 1/31/2013 at 2:33 PM, rafaelfs said: .. http://www.sidefx.co...cs/config_menus Now, while it does work fine here, I'm not proud of the code nor do I guarantee anything! Cheers oho ! it works and you should be proud even if it was only just for the link to onlineDocs .. =) searching with 'menu' keyword on helpSytem brought many other thing , but .. anyway , thanks Rafael . appreciate your reply . .cheers Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted January 31, 2013 Share Posted January 31, 2013 One thing I just realized doesn't work so well is when you append to a string parameter. But I'm fine with it for now, will try to fix it another time. Cheers Quote Link to comment Share on other sites More sharing options...
