HOT Displace artifacts
I know this has been covered here but
somehow displacement bound settings on both the geometry
and the shader are not working for me.
I have attached the file.
The shading quality does make a difference though but I cant
see any changes when I increase the Displace Bounds on the Geometry
SOP and/or the shader.
Thanks,
Bhavesh.
post-4186-0-63845600-1359417836_thumb.jp
ocean_render_artifact.hip
Hey Igor! Thanks for confirming this.
Yes I noticed it too. But wasn't it documented in the help docs that PBR might give artefacts when displacing geo
but micro poly should be better?? (which is why I also tried micro poly pbr but thats also screwed up).
I'm quite confused with this.
Edit:
If the displacements are getting clipped shouldn't the alpha be 0 in those areas? For me the alpha looks ok..just the colour is black.
Edited by bhaveshpandey
  • 6 months later...
