beltrajo3 Posted January 29, 2013 Share Posted January 29, 2013 Alright I'm still quite new to Houdini but I'm enjoying its shattering system and its dynamics are much more viable to use over the likes of Maya. My question is whether or not it is possible to bake object shattering and interactions with other objects as set keyframes. Reason for this is so I could possibly transfer it over as an FBX file to Maya. I apologize if this seems a bit obvious of a question. Thanks for any help, Belt Quote Link to comment Share on other sites More sharing options...
michael Posted January 29, 2013 Share Posted January 29, 2013 do you just want to export the geometry to Maya? if so just export as FBX or alembic Quote Link to comment Share on other sites More sharing options...
zeekindustries Posted October 5, 2013 Share Posted October 5, 2013 I've been experimenting some problems working with the FBX export, whenever I want to export some objects with keyframes I get this error Untied key values. This is not supported. But the FBX still exports with all the range of keyframes but with all the values multiplied by .5, has this happened to anyone or do you know if this is a bug or if it has some sort of workaround? Quote Link to comment Share on other sites More sharing options...
mimbik Posted January 26, 2017 Share Posted January 26, 2017 For those having problem " Untied key values. This is not supported. " you need select an object and in Animation Editor, select all keys and choose "Tie values". Quote Link to comment Share on other sites More sharing options...
