magneto Posted January 30, 2013 Share Posted January 30, 2013 Hi, Whenever I start Houdini, the viewport scene renderer is set to H11. Is this the new default for now? Can I override it to use OpenGL 3.2? Because it reverts back after restarting it. Thanks Quote Link to comment Share on other sites More sharing options...
malexander Posted January 30, 2013 Share Posted January 30, 2013 The default is GL3 for all hardware GL implementations capable of GL3.2 (excluding Nvidia 195/197 series, which had severe bugs, and OSX, which implemented a separate GL3 driver from its GL2 driver). You get GL1 for Linux/Mesa, and H11 for Windows software rendering. If you save the preference as GL3 in Main Prefs > Viewport, and Accept, it should save itself to $HOME/houdini12.1/houdini.pref (glrenderer.val) and be restored upon next startup. This value is not saved to a .hip file. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted January 30, 2013 Author Share Posted January 30, 2013 Thanks Mark, now it works. Not sure what the problem was, because the pref file had "GL3" value. But I also switched to the latest build now, so maybe this helped too. Quote Link to comment Share on other sites More sharing options...
