Doum Posted February 1, 2013 Share Posted February 1, 2013 Hey, Anyone can help me with that? I'm trying to visualize an expression inside houdini's viewport by creating a curve using the wanted attribute value, but I'm stuck at a certain point. I'm trying to get an attribute's value of a specific particle created inside a popnetwork from a new geo node (add + point SOP). I tried something like this... points("../../ emitter/popnet1",1,"Spring") I'm not sure if I'm using the right expression? If there is a easier way to visualize expression in a graph in houdini, let me know... I hope it's clear? Someone know a place where I could learn the basic of expression and getting values inside houdini?? thanks Quote Link to comment Share on other sites More sharing options...
Annon Posted February 1, 2013 Share Posted February 1, 2013 looks almost right off the top of my head (no s on the points though, ohh and spaces). point("../path/to/node", pointNumber, "attribute", index) so: point("../../emitter/popnet1", 1, "spring", 0) Not sure on the uppercase S on Spring. Check it out and see. Quote Link to comment Share on other sites More sharing options...
Doum Posted February 1, 2013 Author Share Posted February 1, 2013 Thanks for the help, I had almost the right expression . btw with "point" I have to add the index at the end too. And my bigger problem was that I hadn't check the "match by attribute" box in the pointSOP. Now that it's working is there a way to create a curve base on that point transformation ? I'm trying the trail, but it's doesn't seem to work Quote Link to comment Share on other sites More sharing options...
Annon Posted February 1, 2013 Share Posted February 1, 2013 Yeah have a look at the addSOP. Polygons tab, By Group, then change the add method to attribute and use a custom attribute. Or look at the examples of the add sop to find other ways. Quote Link to comment Share on other sites More sharing options...
Doum Posted February 1, 2013 Author Share Posted February 1, 2013 thanks Christian! Quote Link to comment Share on other sites More sharing options...
