Correcting geo after fracturing
Doum
Thanks for the help acey195,
And what the node to get the closest location of another object (let say the sphere before fracturing) in vop to get the normal or the point position. So I can transfer them to the point fractured...
you can try to use attrib transfer, vopsops only work correctly (most times) when the amount of points on multiple inputs is the same and have the same order (sorting).
"attrib transfer" may give other artifacts though, depending on the relative positions of both inputs.
If the point positions are exactly the same it probably works correctly,
but you do not have points at the fractures on the original mesh,
so that may or may not solve your problem.
After all the useful advices given in this topic by other users I'll be the newb and suggest stupid things (probably you needed this for different effects/looks):
if you are in need of this to be used in a simulation (like the sphere breaking at some point) can't you do it the old fashioned way?
Switch the clean mesh with the fractured one at the frame of impact? It'll stay clean and nice (because it will be the original one) until you need to break it. If it's for some slowmo kind of fracture (so the switch would be more apparent because the sphere would stay intact for more frames after switching to the broken one), you could also try to "blend" between the two using cookie (if the mesh isn't complex) or volume mixing (if you have more complex meshes...and more time :P )
