function order of execution
freaq
Hi guys, I'm new to python and I am trying to make a tool that allows me to create a curve to run a procedure on,
and I want to draw this curve on top of existing geometry.
this I turn on primitive snapping, and other primitives.
the only issue is as the end of the script I want to turn the settings back to their original settings, this works fine with a box for example but not with the curve as I stay inside the toolstate.
the snaping is therefore turned of before I create all the points for my curve. is there a way I can execute it later? I tired to put the code in two functions, executing the second function after the first one was complete,
but still it is executed before. all help is appreciated.
here is my code:
# start of code
# Get the scene viewer and snapping options
snap = hou.ui.curDesktop().paneTabOfType(hou.paneTabType.SceneViewer)
# find whether primitive snapping is on.
text = snap.snappingMode()
text2 = snap.isSnappingToOtherObjects()
#turn on prim snapping
snap.setSnappingMode(hou.snappingMode.Prim)
snap.setSnapToOtherObjects(1)
# the actual script for shooting the curves
def createcurve():
import toolutils
import soptoolutils
activepane = toolutils.activePane(kwargs)
if activepane.type() == hou.paneTabType.SceneViewer:
# Get the current context.
sceneviewer = toolutils.sceneViewer()
# Create a SOP container.
container = soptoolutils.createSopNodeContainer(sceneviewer, "wire_")
# Create the curve.
newnode = soptoolutils.createSopNodeGenerator(container, "curve", None)
# Turn on the highlight flag so we see the SOPs selected output.
newnode.setHighlightFlag(True)
if sceneviewer.isCreateInContext():
newnode.setCurrent(True, True)
sceneviewer.enterCurrentNodeState()
toolutils.homeToSelectionNetworkEditorsFor(newnode)
else:
container.setCurrent(True, True)
toolutils.homeToSelectionNetworkEditorsFor(container)
activepane.setPwd(container.parent())
activepane.setCurrentState("objcurve")
elif activepane.type() == hou.paneTabType.NetworkEditor:
soptoolutils.genericTool(kwargs, "curve")
else:
raise hou.Error("Can't run the tool in the selected pane.")
def cleanup():
# reset the snapping options
#reset snap mode
snap.setSnapToOtherObjects(text2)
snap.setSnappingMode(text)
createcurve()
cleanup()
# end of code
Best regards,
Freek Hoekstra
