MilanSuk Posted February 15, 2013 Share Posted February 15, 2013 (edited) Hi,In attachment you can find fully featured BulletSOP 2.0 beta v5!BulletSOP is implementation of Bullet library 2.8(bulletphysics.org) inside SideFx Houdini. Its a plugin for creating incredible rigid body simulations.Primary it is single-thread application, but speed is very impressive. Memory footprint as well.The most important features of this release is that Its free and without limits(until now up to 5000poly objects). So now you can create real stunning massive simulations.This version is for Windows(64bit), Linux(64bit, gcc4.4) and Mac OSX(10.7), but OSX version is not stable on my system In attachment you can find example file with a lot of scenes, which are which propably the best learning resources at this moment.There is old tutorial(https://vimeo.com/57198443) for alpha version as well.I will make more tutorials for every node. And remember "Details view" is your best friend!!!Changes:- added motion blur output + example scene- faster Delete duplicity for constraints(2.6M constr. take only 4s)- fixed btLoader- added % info to btModify- few optimalization in btTransformAdded new scenes:- building collapse scene(falling floor)- building scene with "snake"- high poly interior details on voronoi pieces- transform soft ropes with rigid bodies- added and changed few others examplesLinkedIn group: http://www.linkedin....Houdini-4796605Sneak Peek(alpha version): https://vimeo.com/57193837Some info about this project: http://www.sidefx.co...wtopic&p=127978Please, If you are interested in this project, take one minute of your time and fill this survey: http://obsurvey.com/...C4-71248188D81CRegards,Milan SukEDIT: The latest beta v6: http://forums.odforce.net/index.php?/topic/17640-bulletsop-20-beta-v6/ BulletSOP_2_beta_v5.zip Edited June 17, 2014 by MilanSuk 8 Quote Link to comment Share on other sites More sharing options...
Leonard Posted February 16, 2013 Share Posted February 16, 2013 Thanks Milan. I got your mail and replied. Hope to get an answer to the issue I raised in the mail. Lots of kudos. Quote Link to comment Share on other sites More sharing options...
Nando Posted February 24, 2013 Share Posted February 24, 2013 I might be stupid with this question, I cannot find the Dso folder in the specified locations, in Mac and Windows. i also created a dso folder and pasted the file, in the downloads but no hope. anyone can help me with this pls Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted February 25, 2013 Author Share Posted February 25, 2013 What version of Houdini do you use? This is compile for 12.1.185(Latest production build). Its working with others, but there is no guarantee. Or Can you install some other plugins(Houdini Ocean Toolkit, ...) and see If it works??? Quote Link to comment Share on other sites More sharing options...
Nando Posted February 25, 2013 Share Posted February 25, 2013 I am using the recent build 12.1.185. The only Problem is i cannot find the specific Dso folder. we ll i have never tried installing Houdini ocean tool kit , i will Give it a Go for sure. but out of curiosity, arent we suppose to have the Dso Folder when installed ?? Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted February 25, 2013 Author Share Posted February 25, 2013 (edited) but out of curiosity, arent we suppose to have the Dso Folder when installed ?? I have reinstalled my OS few days ago and when I installed Houdini I had not DSO folder! Just one more idea is that it needs to be "dso" folder, not "Dso", "DSO", ... folder. This is not problem on Windows, but on Linux It is! edit: And do you have gcc4.4 version? Not older? Edited February 25, 2013 by MilanSuk Quote Link to comment Share on other sites More sharing options...
Nando Posted February 26, 2013 Share Posted February 26, 2013 sorry for the late reply ?? what is gcc4.4 version i am not aware of it Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted February 26, 2013 Author Share Posted February 26, 2013 what is gcc4.4 version i am not aware of it If you go to download page for Houdini you will see for example this: "Ubuntu 9.10 or above(gcc4.4)" Quote Link to comment Share on other sites More sharing options...
Nando Posted February 26, 2013 Share Posted February 26, 2013 okay now i get it I have downloaded gcc4.2 Quote Link to comment Share on other sites More sharing options...
OrangeSed Posted March 2, 2013 Share Posted March 2, 2013 (edited) Thanks Milan, your plugin is totally awesome But I have two questions about things I discovered while working with it.. First, are you planning to add other forces like drag for example? Cause Iam working on an explosion and adjustable drag could be really useful I think... Second is it somehow possbile to limit a force to a specific object group?? To a single object it seems to be possbile with the BT_INDEX, but how to a group of pieces for example? At the moment Iam using a workaround to archieve this effect. Iam copy stamping the BT_INDEX on my force points with all the indexes of the objects I want to affect, but perhaps there is an easier solution.. Thanks again and greetings One more question...can you say when you will release a version without the 5000 objects limit? Edited March 2, 2013 by OrangeSed Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted March 3, 2013 Author Share Posted March 3, 2013 Thanks Milan, your plugin is totally awesome thank you First, are you planning to add other forces like drag for example? Cause Iam working on an explosion and adjustable drag could be really useful I think... You don't need to use Force(s) for this, you can animate,set,multiply, ... velocity of objects with btModify(RBDs tab) Second is it somehow possbile to limit a force to a specific object group?? To a single object it seems to be possbile with the BT_INDEX, but how to a group of pieces for example? At the moment Iam using a workaround to archieve this effect. Iam copy stamping the BT_INDEX on my force points with all the indexes of the objects I want to affect, but perhaps there is an easier solution.. True, only solution at this moment is copying same force with different object index and applying forces is very fast inside solver, but not so user-friendly, I will look at it. One more question...can you say when you will release a version without the 5000 objects limit? This(beta v5) is without limit!!! Quote Link to comment Share on other sites More sharing options...
Zach Posted March 7, 2013 Share Posted March 7, 2013 hey, that obsurvey link just takes me to a thing that says "thank you" - is it supposed to do that? Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted March 8, 2013 Author Share Posted March 8, 2013 (edited) hey, that obsurvey link just takes me to a thing that says "thank you" - is it supposed to do that? It's probably because somebody has voted from your IP or computer. Or maybe some problem on server.Anyway, I think that survey has enough votes, for making some results.There will be one more beta which will introduce btCompound shape, so you will be able to combine more shapes to one object, which is very useful. Edited June 17, 2014 by MilanSuk Quote Link to comment Share on other sites More sharing options...
billlovecg Posted March 17, 2013 Share Posted March 17, 2013 support for H12.5? Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted March 17, 2013 Author Share Posted March 17, 2013 support for H12.5? I can't download it! I try Win7 version and It always downloads max. 20MB Quote Link to comment Share on other sites More sharing options...
thomthom Posted March 17, 2013 Share Posted March 17, 2013 I can't download it! I try Win7 version and It always downloads max. 20MB By any chance do you have Avast ? Because it happen to me and just disabling Avast for an hour solve the problem. Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted March 17, 2013 Author Share Posted March 17, 2013 By any chance do you have Avast ? Because it happen to me and just disabling Avast for an hour solve the problem. You're right, this was my problem, so I installed it and I had to change project settings, because It seems that 12.5 has many changes in HDK, but source code is fine, so I didn't change anything. In attachment you can find version for Windows 64bit! Win7_12.5.316.22.zip Quote Link to comment Share on other sites More sharing options...
horizon1231 Posted March 18, 2013 Share Posted March 18, 2013 In attachment you can find version for Windows 64bit! this compilation for 316 can't work for version343,weird... previous compilation for H12.1 dont have such minor version restriction. Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted March 18, 2013 Author Share Posted March 18, 2013 this compilation for 316 can't work for version343,weird... previous compilation for H12.1 dont have such minor version restriction. yes, It's pain in the ass, but you can install more version of Houdini and just make RBD sims data in version where BulletSOP works. I will compile BulletSOP for every production build and of course there will be option to buy source code, so you will be completely independent! Quote Link to comment Share on other sites More sharing options...
cgstar Posted April 1, 2013 Share Posted April 1, 2013 (edited) Everybody is good! Need you help!In the broken phenomenon of irregular objects will appear split! How to solve? bt.hipnc Edited April 1, 2013 by cgstar Quote Link to comment Share on other sites More sharing options...
