MilanSuk Posted April 2, 2013 Author Share Posted April 2, 2013 On 4/1/2013 at 11:54 PM, cgstar said: Everybody is good! Need you help!In the broken phenomenon of irregular objects will appear split! How to solve? There is a bug inside Bullet Library(not in my plugin), so use concave bodies is not safe at this moment Solution is create btModify after btBuild1 and set convex to 1. The outside pieces will not have accurate collision, but you didn't applied so much mountain, so you don't probably note this. My example scene(you downloaded it with plugin) includes example for high/low objects, which is in your case good to study! Quote Link to comment Share on other sites More sharing options...
cgstar Posted April 2, 2013 Share Posted April 2, 2013 HI !MilanSuk Thank you very much! Quote Link to comment Share on other sites More sharing options...
csmnt Posted April 5, 2013 Share Posted April 5, 2013 Hi! I am testing the plugin right now. It's really super fast and has a cool workflowl! One thing though, I couldn't get to work: What I'd like to do is animate the rbds collision property. I am emiting rbds much like in the provided example, but I would like them to start inside an object and just start colliding with it when they are not inside of it anymore. I looked into the collision groups example but they also collide when intersecting on the first frame, it only works after they are initialised in a non intersection position. In my scene I have a prebaked ground explosion and would like to add some more rbd debris, but for this to look good they have to come from within the surface. So something simple like collision: if($F>4,1,0) would work, I just dont know where to put that expression. I tried setting margin to a negative value which deactivated the collision, but when animating it it didn't update. Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted April 5, 2013 Author Share Posted April 5, 2013 On 4/5/2013 at 12:37 PM, csmnt said: Hi! I am testing the plugin right now. It's really super fast and has a cool workflowl! thank you On 4/5/2013 at 12:37 PM, csmnt said: I looked into the collision groups example but they also collide when intersecting on the first frame, it only works after they are initialised in a non intersection position. I checked it and it's probably a bug. I will look into it! Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted April 5, 2013 Author Share Posted April 5, 2013 New video: https://vimeo.com/63428212 Cooool! Quote Link to comment Share on other sites More sharing options...
CeeGee Posted April 5, 2013 Share Posted April 5, 2013 Realy nice video, thanks for sharing Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted April 6, 2013 Author Share Posted April 6, 2013 On 4/5/2013 at 9:07 PM, CeeGee said: Realy nice video, thanks for sharing thx, I implemented more features than you can see in this video, they are not so awesome, so I didn't talk about them, but they are very useful ! Quote Link to comment Share on other sites More sharing options...
horizon1231 Posted April 7, 2013 Share Posted April 7, 2013 On 4/6/2013 at 12:48 PM, MilanSuk said: thx, I implemented more features than you can see in this video, they are not so awesome, so I didn't talk about them, but they are very useful ! Could you please bring back the fluid of bullet? thats mostly I want... Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted April 7, 2013 Author Share Posted April 7, 2013 On 4/7/2013 at 2:35 AM, horizon1231 said: Could you please bring back the fluid of bullet? thats mostly I want... Sorry, but no, I can't. It takes a lot of time to create good fluid solver and I think that SESI did a great job in this area and I have a feeling that We will simulate fluids on GPU soon. And bullet RBD solver running on GPU is going to come VERY soon! Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted April 7, 2013 Author Share Posted April 7, 2013 On 4/5/2013 at 12:37 PM, csmnt said: Hi! I am testing the plugin right now. It's really super fast and has a cool workflowl! One thing though, I couldn't get to work: What I'd like to do is animate the rbds collision property. I am emiting rbds much like in the provided example, but I would like them to start inside an object and just start colliding with it when they are not inside of it anymore. I looked into the collision groups example but they also collide when intersecting on the first frame, it only works after they are initialised in a non intersection position. In my scene I have a prebaked ground explosion and would like to add some more rbd debris, but for this to look good they have to come from within the surface. So something simple like collision: if($F>4,1,0) would work, I just dont know where to put that expression. I tried setting margin to a negative value which deactivated the collision, but when animating it it didn't update. I just fixed a bug with collisions groups and I implemented that If you set mass < 0, it set positive mass, but object will be without collisions with others(ghost) and of course you can animate it It means: mass > 0 - dynamic mass = 0 - static or animate mass < 0 - dynamic without collisions I hope that this simplify solving your problem to minimum Quote Link to comment Share on other sites More sharing options...
csmnt Posted April 7, 2013 Share Posted April 7, 2013 On 4/7/2013 at 3:32 PM, MilanSuk said: I just fixed a bug with collisions groups and I implemented that If you set mass < 0, it set positive mass, but object will be without collisions with others(ghost) and of course you can animate it It means: mass > 0 - dynamic mass = 0 - static or animate mass < 0 - dynamic without collisions I hope that this simplify solving your problem to minimum Yes this sounds like it solves the problem! Thanks a lot! ..so this fix will be in beta_v6? Do you already know when you plan to release it? btw, compounds in the latest video seem very usefull! great addition! Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted April 8, 2013 Author Share Posted April 8, 2013 On 4/7/2013 at 9:03 PM, csmnt said: Yes this sounds like it solves the problem! Thanks a lot! ..so this fix will be in beta_v6? Do you already know when you plan to release it? btw, compounds in the latest video seem very usefull! great addition! thx, I want to release beta_v6 end of this week, but I can't give you guarantee. I also experiment with more stable concave objects(btCompound from tetrahedrons), it's slower than GImapact, but stable. Quote Link to comment Share on other sites More sharing options...
sanchoflat Posted April 10, 2013 Share Posted April 10, 2013 (edited) Awasome work! One question - would you like to create some new video tut for last versions or some documentation? Edited April 10, 2013 by sanchoflat 1 Quote Link to comment Share on other sites More sharing options...
zarti Posted April 11, 2013 Share Posted April 11, 2013 i liked very much the last video . hope you find some time for those too . !thanks Quote Link to comment Share on other sites More sharing options...
sanchoflat Posted April 11, 2013 Share Posted April 11, 2013 And one question - on win8 it works fine, but i dont understand, how instal it on linux ( mint ). Or it doesn't work with 12.5? Thx. Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted April 11, 2013 Author Share Posted April 11, 2013 On 4/10/2013 at 3:18 PM, sanchoflat said: Awasome work! One question - would you like to create some new video tut for last versions or some documentation? thx, I will create tutorials after releasing next beta. On 4/11/2013 at 2:12 PM, sanchoflat said: And one question - on win8 it works fine, but i dont understand, how instal it on linux ( mint ). Or it doesn't work with 12.5? Thx. version for 12.5 is only for win, you need to wait for next beta, which will roll on linux too. On 4/11/2013 at 12:49 PM, zarti said: i liked very much the last video . hope you find some time for those too . !thanks thx Quote Link to comment Share on other sites More sharing options...
Dispel Posted April 13, 2013 Share Posted April 13, 2013 Awesome work Milan, I experienced1.5 order of magnitude efficiency gain over using bullet w/ DOPs.. Love it. Only problem for me is I can't seem to find "bounce" parameter for RBDs and I am having trouble simulating a drag force.. Perhaps you can create an example of this? In a previous thread you mentioned using btmodify and manipulate velocities, but I experience trouble getting the drag effect with this. What is the maximum number of RBDs you have been able to simulate yourself? I am trying to achieve the highest possible for my system. It seems RAM requirements are less than DOPs. Quote Link to comment Share on other sites More sharing options...
Dispel Posted April 13, 2013 Share Posted April 13, 2013 I also have unstable results with small objects... How can I do this? Objects roughly 5cm size, they appear to lose/gain energy and never stop spinning no matter what my damping is set to. Similar funny results when setting framerate high. Quote Link to comment Share on other sites More sharing options...
Dispel Posted April 13, 2013 Share Posted April 13, 2013 Here is a quick video to show what I mean by unstable. and if I raise FPS to 240 for example (and adjust solver steps) it appears like they bounce, sometimes with more energy than they had on the previous bounce. Very weird. Sometimes they can jiggle like that endlessly (I already put damping very high for all objects and this is result, even worse with it at 0) coins.movFetching info... Quote Link to comment Share on other sites More sharing options...
MilanSuk Posted April 13, 2013 Author Share Posted April 13, 2013 (edited) On 4/13/2013 at 3:28 AM, Dispel said: Awesome work Milan, I experienced1.5 order of magnitude efficiency gain over using bullet w/ DOPs.. Love it. Only problem for me is I can't seem to find "bounce" parameter for RBDs and I am having trouble simulating a drag force.. Perhaps you can create an example of this? In a previous thread you mentioned using btmodify and manipulate velocities, but I experience trouble getting the drag effect with this. What is the maximum number of RBDs you have been able to simulate yourself? I am trying to achieve the highest possible for my system. It seems RAM requirements are less than DOPs. Thank you "bounce" is "restitution" and you can change it with btModify. For maximum number of RGBs you can check this video: https://vimeo.com/58955642 It's not about finding max. objs, but you get the idea. On 4/13/2013 at 3:41 AM, Dispel said: I also have unstable results with small objects... How can I do this? Objects roughly 5cm size, they appear to lose/gain energy and never stop spinning no matter what my damping is set to. Similar funny results when setting framerate high. In bullet documentation you can find that bullet solver is not cool with objects, which have size under 0.1m(10cm), so maybe this can be problem You can try to scale up your scene, hope this will help. Edited April 13, 2013 by MilanSuk Quote Link to comment Share on other sites More sharing options...
