wall of the water
acti
You can prob do it with a shader or a noisy grid if you wanted... If you actually need water or a fluid sim, create your geometry and use the shelf tools as a start to set up the wall as a static object and emit flip from a cylinder or something. You'll have to be more specific about what problems you're running into with it (have you even tried doing it yet??) for anybody to help you out.
sorry my english is not good so I don't know how to represent that clearly. now i'm trying give a different value of friction to the collide object of flip and it looks a little better.I have used noisy grid but the result is not very well,I want to add more detail on it,thanks for the answers.
