Whatsinaname Posted March 3, 2013 Share Posted March 3, 2013 Maybe this is one of those "stupid questions" so please be patient.... Is there a way I can start Houdini in command line/ shell mode so it can simulate stuff without having to load the GUI before? Example: In Realflow (some of you might know that software), I can set up a scene using the GUI, test if the simulation works fine...and then have the simulation done via a command line/ shell comand so the software doesn't need to load the GUI and consume extra memory. I have a stand alone (Educational License) of Houdini and don't just need it to simulate some fluids/ liquids. What do I need to do in order to work that way in Houdini? Thank you in advance for any hints! Quote Link to comment Share on other sites More sharing options...
graham Posted March 3, 2013 Share Posted March 3, 2013 Launch hscript for Hscript commands or hython for Python commands. Quote Link to comment Share on other sites More sharing options...
ikarus Posted March 4, 2013 Share Posted March 4, 2013 http://www.sidefx.com/docs/houdini12.1/rendering/commandline Quote Link to comment Share on other sites More sharing options...
DanBode Posted March 5, 2013 Share Posted March 5, 2013 http://www.sidefx.co...ing/commandline Of the ways listed there I find hrender to be by far the easiest. (I wanted to point it out because it's easy to miss on that page.) Quote Link to comment Share on other sites More sharing options...
xmetallicx Posted March 14, 2013 Share Posted March 14, 2013 You could use hbatch command in the shell to open your hip file then "opparm -c yourNode execute" would cook/simulate your node in commandline. Quote Link to comment Share on other sites More sharing options...
Skip Posted March 16, 2013 Share Posted March 16, 2013 Hi there, I'm trying to do a similar thing right now. You should be able to create a "Dynamics Output Driver" much like a mantra output node, and render that using hrender as suggested above. You have to specify the dopnet in the settings and it will look for the display/render flag in the dopnet (so I suggest sticking a null at the end of the chain for tidiness reasons ) However, my version of apprentice HD doesnt seem to have the dynamics output node and I'm looking into why. But I did use this feature yesterday on my Uni's education edition and it works wonders Quote Link to comment Share on other sites More sharing options...
graham Posted March 16, 2013 Share Posted March 16, 2013 Apprentice licenses don't support additional output drivers, which is what the Dynamics ROP basically is: it writes .sim files. Since there is no non-commercial version of .sim there's nothing to stop someone from running a simulation in Apprentice and then importing it into a commercial version and continuing on. Quote Link to comment Share on other sites More sharing options...
Skip Posted March 16, 2013 Share Posted March 16, 2013 Thanks for clearing that up for me Graham, much appreciated. I had considered that as the reason. But couldn't really get my head around it as I could run the sim from within the gui and export it from there via a "File" or "Rop_Dop" . Not having the Dynamics ROP wouldn't stop anyone taking that approach? All I want to do is run some sims from terminal. Ah well, thanks for the reply Quote Link to comment Share on other sites More sharing options...
