FlipBook
Hello,
Is there other way to include other information into flipbook, Such as particle/poly count or file name? I may forgot to mention "Flipbook Session Label" isn't functioning for me.
Thanks in advance,
Amin
Edited by amination
If you look through a particular camera when you do the flipbook, then the camera can have the "Viewport Comment" parameter set to $HIPNAME. Gear icon menu on the camera parameters > Edit Rendering Parameters > Viewport Display > OpenGL View > Viewport Comment. If it's just a particular object, then you add a `npoints("/path/to/sop/node")` expression there to include it as well. Or, if you're using H12.5, you can turn on the new display option that shows point/poly counts.
  • Like 2
