sorting array - again
I am still struggling to sort arrays in the HDK and hence I have a couple of questions.
For example, if I have added a float attribute to my primitives how can I sort the primitives according to these values? I know how to access and read the attribute into the HDK but have no idea what I should do next.
And the other question is: How do I sort a UT_ValArray of vectors by the length of the vector?
Here is what I have so far:
GA_ROAttributeRef myattrib;
myattrib = gdp->findPrimitiveAttribute("area");
GA_ROHandleF myhandle(myattrib.getAttribute());
for(GA_Iterator it(gdp->getPrimitiveRange()); !it.atEnd(); it.advance()){
cout << myhandle(it.getOffset()) << endl;
[/CODE]
Any help would be appreciated!
[/CODE]
to sort prims you'll need to reorder the corresponding GA_IndexMap which basically is responsible for the prim-numbering you see in the viewport.
[CODE]
// get index map
GA_IndexMap &indexMap = gdp->getIndexMap(GA_ATTRIB_PRIMITIVE);
// set comparator
GA_IndexMap::AttributeCompare compare(myattrib.getAttribute(), 0);
// instead of using your myattrib it´s possible to access the attribute direcly
// GA_IndexMap::AttributeCompare compare(indexMap, "area", 0);
// sort indexMap
indexMap.sortIndices(compare);
// NOTE:
// you could change
GA_ROAttribRef areaAttribRef = gdp->findPrimitiveAttribute("area");
GA_ROHandleF areaHandle(areaAttribRef.getAttribute());
// to
GA_ROHandleF areaHandle(gdp, GA_ATTRIB_PRIMITIVE, "area");[/CODE]
for this you´ll need a comparison function
[CODE]
// comparator
int compare(const UT_Vector3 *vec1, const UT_Vector3 *vec2)
if(vec1->length() < vec2->length())
return -1;
if(vec1->length() > vec2->length())
return 1;
return 0;
UT_ValArray<UT_Vector3> vecArray;
// sort array
vecArray.sort(compare);[/CODE]
hth.
petz
Edited by petz
You can use the sortPrimitiveList() with the float * signature to essentially sort by attribute value/expression using some supplied list of values.
The following 2 lines mimics 4 primitives (0,1,2,3) with respective attribute values (1,3,2,0). After sorting, they will be sorted in increasing order of the corresponding values.
float order[4] = {1, 3, 2, 0};
gdp-&gt;sortPrimitiveList(order);
Thanks Graham, it´s starting to make sense now. But still one question remains. If I want to sort the primitives by an attribute, for example the area, do I have to create the list of floats first? Or, to rephrase the question, what would be the preferred way to have "area" accessible to sortPrimitiveList()?
Yeah, you would basically need to create the list of values from the attribute values. I believe there is a function for point attributes that will return all the values in a flattened array, but I don't believe such a function exists for primitive attributes.
to get an array from the primitive attribute values you may want to use GA_AIFTuple. that way you´ll get floats which could be directly used by sortPrimitiveList() in GU_Detail.
but even so, if you´ll have to sort primitives by existing attribute values i would use the method i´ve posted before. it´s cleaner and considerably faster.
hth.
petz
just for completion....
// get attribute
GA_ROAttributeRef areaAttribRef = gdp->findFloatTuple(GA_ATTRIB_PRIMITIVE, "area", 0);
// get GA_AIFTuple
const GA_AIFTuple *areaTuple = areaAttribRef.getAIFTuple();
// allocate array
float *areaArray = new float[gdp->getNumPrimitives()];
// get array of values
areaTuple->getRange(areaAttribRef.getAttribute(), gdp->getPrimitiveRange(), areaArray);
// sort prims
gdp->sortPrimitiveList(areaArray);
// cleaning
delete [] areaArray;
[/CODE]
