FLIP - Transfering Normal Data to Particles
gramx
Hi
Stuck! I am doing a test where I have exported the whitewater spray to a bgeo cache. I am then reading it back in and using a particlefluidsurface to mesh it. I am trying to use attribute copy to copy the normals from the mesh onto the particles. Not working yet! I want to read the closest point to surface and add the normal direction to the attributes of the particle so that I can then render particles with surface normals in krakatoa. I am exporting PRT.
I also want to do the same thing to the particles of a flip fluid.
Thanks for any help.
Graham
I've got it working with the Attribute transfer :) there are some good examples in the help!
Thanks for the hip file Filipp I will take a look at that, a bit of extra speed will be a good thing when I try it with 20million particles!
Thanks for help!
graham
Edited by gramx
