Ezz Posted April 18, 2013 Share Posted April 18, 2013 Hi good folks. I am looking for a way to create a velocityfield from and object using a SDF. But I have troubles understanding the workflow on how to transfer the SDF to a gradientfield etc. Please help. Cheers Erik Quote Link to comment Share on other sites More sharing options...
vi_rus Posted April 18, 2013 Share Posted April 18, 2013 Hey man, You need to create an empty vector volume(via volume SOP) at first and then use VolumeFromAttrib SOP. It's the most simplest way. I don't get, why do you want to use gradient? Quote Link to comment Share on other sites More sharing options...
bloomendale Posted April 18, 2013 Share Posted April 18, 2013 You can use gas analysis dop or volume analysis sop depending on where you want to create your vel field Quote Link to comment Share on other sites More sharing options...
Ezz Posted April 18, 2013 Author Share Posted April 18, 2013 Hey guys.. Thank a lot for your suggestions - I will look into it. Cheers Erik Quote Link to comment Share on other sites More sharing options...
