saelly Posted April 27, 2013 Share Posted April 27, 2013 (edited) gigabyte Notebook U2442D OS: ubuntu 13.04 graphic: intel HD 4000 & NVIDIA geforce 730m (( ex) optirun bash -> houdini ) open Terminal -> optirun bash -> source houdini_setup_ bash -> houdini -> openCL Exception: No OpenCL platform found. (-32) and.... openCL option in pyro -> check!! -> houdini exit.... my log.txt Crash report from sungchul; Houdini FX Version 12.5.371 [linux-x86_64-gcc4.4] Traceback from Sat Apr 27 23:18:17 2013 Caught signal 6 AP_Interface::coredumpHandler(UTsignalHandlerArg) <libHoudiniUI.so> UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo*, void*) const <libHoudiniUT.so> UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so> _L_unlock_13 <libpthread.so.0> raise <libc.so.6> abort <libc.so.6> __gnu_cxx::__verbose_terminate_handler() <libstdc++.so.6> std::rethrow_exception(std::__exception_ptr::exception_ptr) <libstdc++.so.6> std::terminate() <libstdc++.so.6> __cxa_rethrow <libstdc++.so.6> UI_Queue::drain() <libHoudiniUI.so> UI_Queue::eventLoop() <libHoudiniUI.so> main_part2(int, char**) <libHoudiniUI.so> main <libHoudiniUI.so> __libc_start_main <libc.so.6> _start <houdini-bin> how to...fix.. Edited April 27, 2013 by saelly Quote Link to comment Share on other sites More sharing options...
edward Posted April 27, 2013 Share Posted April 27, 2013 Try optirun houdini-bin Quote Link to comment Share on other sites More sharing options...
