How to ewxport to 3d paint package
There is no plugin connection like with other apps, however, you can easily export your object as an OBJ, it will retain one set of UV coordinates (the first set) per vertex. Then, just load the OBJ in your paint package, apply a material and texture, and paint. To export to obj, just right click on a sop and select "Save Geometry" or use a Geometry ROP.
If you need more than one set of UV coordinates, just export mulitple obj's, each containing a set of UV coordinates.
