Houdini Crash when using created node through HDK.
It's really hard to say anything with no details. What does debug output prints?
I've briefly checked, and it compiles and doesn't crash at Linux 12.5.344, although I have no idea what it does atm.
I'm using Window8.
I found solution and not crash anymore.
But I really cannot understand it. :(
The solution is that, in Visual Studio,
<Release Mode, C/C++ - Command>
-TP
-Zc:forScope
-DVERSION="12.5.316.22"
-DI386
-DWIN32
-DSWAP_BITFIELDS
-D_WIN32_WINNT=0x0501
-DWINVER=0x0501
-DNOMINMAX
-D_USE_MATH_DEFINES
-D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE
-D_SCL_SECURE_NO_WARNINGS
-DBOOST_ALL_NO_LIB
-I .
-I "C:/Program Files (x86)/Microsoft Visual Studio 9.0/VC/include"
-I "C:/Program Files/Microsoft SDKs/Windows/v6.0A/Include"
-I "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.22/toolkit/include"
-MD
-EHsc
-GR
-bigobj
-wd4355
-w14996
-DSESI_LITTLE_ENDIAN
-DAMD64
-DSIZEOF_VOID_P=8
-DMAKING_DSO
<Debug Mode, C/C++ - Command>
-TP
-Zc:forScope
-DI386
-DWIN32
-DSWAP_BITFIELDS
-DWINVER=0x0501
-D_USE_MATH_DEFINES
-DBOOST_ALL_NO_LIB
-I .
-MD
-EHsc
-GR
-DAMD64
-DSIZEOF_VOID_P=8
-DMAKING_DSO
So between this two mode, difference is
Just Release mode has below command,
-DNOMINMAX
-bigobj
-wd4355
-w14996
If Release Mode doesn't have this command, Houdini is crashed when I creat HDK node.
Could you guys give me some advices about this commands?
Edited by kidsreturnjj
Guest mantragora
-DNOMINMAX
-bigobj
-wd4355
-w14996
Hm, have you used solution made by me that I posted on SESI forums some time ago ? If so, it needs to be updated because as you can see yourself there are couple of additional flags added. I can see that you are missing even more than those.
C/C++
-TP
-Zc:forScope
-nologo
-DVERSION="$(H12_VERSION)"
-DI386
-DWIN32
-DSWAP_BITFIELDS
-DWINVER=0x0501
-DNOMINMAX
-D_USE_MATH_DEFINES
-DBOOST_ALL_NO_LIB
-I .
-I "$(VS2008_PATH)/VC/include"
-I "$(H12_PATH)/toolkit/include"
-MD
-EHsc
-GR
-bigobj
-wd4355
-w14996
-DSESI_LITTLE_ENDIAN -DAMD64
-DSIZEOF_VOID_P=8
-DFBX_ENABLED=1
-DOPENCL_ENABLED=1
-DOPENVDB_ENABLED=1
-DMAKING_DSO
Linker:
/libpath:"$(VS2008_PATH)/VC/lib/amd64"
/libpath:"C:/Program Files/Microsoft SDKs/Windows/v6.0A/Lib/x64"
"$(H12_PATH)/custom/houdini/dsolib/*.a"
"$(H12_PATH)/custom/houdini/dsolib/*.lib"
Thanks so much to reply!
But unfortunatly, it doesn't work for me, so I'm using hcustom to compile examples for studying..
I would like to ask you some thing more.
How could you get bellow command?
-DFBX_ENABLED=1
-DOPENCL_ENABLED=1
-DOPENVDB_ENABLED=1
I follow this link steps,
http://vimeo.com/17195536
but I couldn't get above commands.
Thanks!
Guest mantragora
If you use this command
hcustom -d foo.cpp
in Houdini CommandLineTools, it wll print all the flags it uses. If you followed tutorial above, maybe you just deleted them.
PS. Try this VS solution http://www.mediafire...dcudei85x3xcujx. It should work with H12.5. Before you run it, read my post here to know what variables you need to setup to make it work.
PS2. Maybe I should make tutorial on how to setup VS for Houdini. I'm a little better at speaking english than author of your tutorial ;)
Edited by mantragora
