dark_cry Posted May 20, 2013 Share Posted May 20, 2013 Hey guys, i watched some videos about rayfire. In fact it has great fracture tool. I like wood fracture. I believe in houdini it's possible to build same fx. I'm not talking about the fracture itself, but adding some detail to inside points. Here my setup, it works not bad, but have some problems. The setup is pretty simple. I did it in sop level but same thing could be done in shops. Would be great if someone could offer more relieble method. woodFracture.hip Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted May 20, 2013 Share Posted May 20, 2013 This is another method, use the Voronoi fracturing nodes but scale the object before and after the break to get the elongated pieces. http://www.digitaltutors.com/lesson/7102-Fracturing-objects-with-grain-like-wood The example in the video is fairly simple but you could take the concept and run with it. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted May 21, 2013 Share Posted May 21, 2013 Here's a non-commercial scene file demonstrating what I was talking about in the last post. The more points you add the finer the grain will be. woodBreaking.hipnc 1 Quote Link to comment Share on other sites More sharing options...
3__ Posted May 21, 2013 Share Posted May 21, 2013 see attached. Luke's method is preferable if you want to animate specific breakage, rather than spewing random debris into a sim... woodFracture_8n.hipnc Quote Link to comment Share on other sites More sharing options...
dark_cry Posted May 24, 2013 Author Share Posted May 24, 2013 thnx guys all for comments, i really appreciate it Quote Link to comment Share on other sites More sharing options...
