Mantra Rendering previous image again!
My problem is that if I do a single frame render then its fine but if I do an animation range then mantra is compositing next image render on previous one. If I interrupt render and start from next frame then its fine again. For 20 frames I will have to render it 20 time seperately. If I leave it to mantra, it will composite on top instead on rendering new fresh image. Is there a way that mantra refreshes its cache before every render?
What is the frame rate ? match the same frame rate in the compo. Houdini is 24 by default ?
This is really strange and never heard anything like this ever. ??
can you maybe put up the hip file with the render settings etc.....
I would just like to se the mantra node:
cheers
mangi
